hey Lavoy,
on the starter solenoid cable bolt that goes from solenoid to the starter itself, mine has a flat piece bent at right angle to the starter and it tends to throw a spark from under it....is that supposed to have some kind of insulator under it? it kinda looks like something is missing. as long as i tighten it up every so often it does not throw the spark....i sure don't want that to continue...change the solenoid? is it specific to deere?
re..jd440ic starter solenoid
Re: re..jd440ic starter solenoid
Not sure, can you post a pic?
Users browsing this forum: gus and 305 guests
