JD 440 ICD oil filter
I can not find the oil filter on this machine. Other posts say it is on the left of motor under tank and behind governor. Is it possible it was removed? I don't see any lines blocked off / missing. Anyone have a picture?
Re: JD 440 ICD oil filter
Look st this video, in the first half of the video you can see a large plate with about a 3 inch hole in it between the hood and the track. My oil filter is mounted just inside that plate, horizontally. It is a bypass style filter and the lines run down in front of and below the governor.
https://www.youtube.com/watch?v=U2n2_ZxIr3s
Thanks, I looked at the video and found some pictures. The filter is definitely gone. Does anyone have a close up photo of where the oil lines connect into the block? I'm going to put a spin on filter on it if I can find a kit.
The filter is located in a horizontal fairly large round steel canister on the left side of engine.
Napa Gold 1100 (WIX 5110) filters fit what I have.
http://www.wixfilters.com/Lookup/Applic ... ?Section=4
Here is an old photo:
http://imgbox.com/p9IKPvuh
1959 440 ICD with 6-way hydraulic blade.
I had trouble finding a filter on my location . I we to hhe local hot rod shop and purchased a remote filter kit that uses ford filter
I hope that works well for you.
The original is a fairly large filter with OD 4.1" and 5" height.
As far as I know, the same filter was also used in many Cadillac models (51-58) and other GM Cars/Trucks (50-62) from the same era.
Users browsing this forum: KPaXz and 219 guests
