engine oil pressure///jd440ic
dtoots1
Post by dtoots1 » Mon Sep 25, 2017 12:04 pm
Finally got a new oil pressure gauge with numbers....the old electric operated original? kept showing up on the redline///shutoff line.....scary...
new gauges shows that i have something over 20psi oil pressure....gauge reads 20 40 60 and have to kinda guess at approximately 23 to 25psi. i think that i am running 10w30....book calls for 20w and says is ok to use 10w30. does not call for 30weight.
i do have a donor engine with oil pump in it could maybe rebuild and replace mine....but i don't know if this one has to be timed to work properly or if pressure i have will still be ok at 20 something,
need your inputs please
thanks
Dtoots1
Re: engine oil pressure///jd440ic
Post by Lavoy » Mon Sep 25, 2017 1:11 pm
Pressure is fine, any good multi weight gas rated oil is fine as well.
dtoots1
Post by dtoots1 » Mon Sep 25, 2017 2:58 pm
that is great news..... thanks...
now question.....there is an oil port just a bit behind the hydraulic pump on the right side of engine...it has a nipple and a plug in it.....is this a test port for the hydraulic pressure.?if so i don't want to put a low pressure gauge on that......on a 2010 that is location for the oil pressure gauge. i don't find an access port on the hydraulic valve body...it is a six way blade.
i used the port for the sending unit when i put the oil pressure gauge in...that is located at the oil filter base....
thanks
dtoots1
Post by Lavoy » Tue Sep 26, 2017 8:40 am
It can be, it is normally where the pressure switch for electric hour meter goes.
Users browsing this forum: No registered users and 376 guests
