re..jd440 ic....edit battery 12volt
dtoots1
Post by dtoots1 » Fri Feb 10, 2017 5:29 pm
well
edit
as you can see one word post gets her to page 2 ...no problem
as paul harvey says..here is rest of story...or some of it...got her home today...find he actually has side posts set up for it.. just got her back at 6:30 left at 0800 ...no problems tho thank the good lord..
so now i have the extra engine..froze up but will see....tranny and reverser from the donor....will see what cleans up..donor was a loader and someone scavenged starter, rad hydraulics and hyd pump off it...
i do have extra steering lever gotta see which side it is....
will get pics and upload soon
dtoots1
Post by dtoots1 » Wed Mar 08, 2017 10:50 am
lucked out....he has already changed battery to side post! solves that issue
thanks
dtoots1
dtoots1
Re: re..jd440 ic....edit battery 12volt
Post by dtoots1 » Mon May 01, 2017 10:31 am
re...starter
from looking at this starter....what i can see of it...looks like a gm starter and may well be a 12 volt...dang thing buried in there and can really only see the rear end of it.....certainly looks different than the 6volt on my jd40s wheeled tractor and donor engine don't have one!...will see one day when can get to it.
dtoots1
Post by Lavoy » Mon May 01, 2017 1:51 pm
Twice the speed, and twice the energy, which is about 4 times as bad as far as potential damage.
440 iron popper
Post by 440 iron popper » Mon May 01, 2017 7:43 pm
Does someone know the resistance of a 6 V starter armature Or have one on hand and can measure it. I would validate what i have then (3 starters on hand). Thanks!
Post by Lavoy » Mon May 01, 2017 8:05 pm
40 and 440 are different starters. If yours looks like a GM starter with a solenoid, then you must have a diesel.
