roller grease gun
1954cooter
roller grease gun
Post by 1954cooter » Thu Mar 30, 2017 12:04 pm
I got an old pail type grease gun that came with my TD9.I checked the pressure and it only makes 1500 psi.What you guys think about using this with corn head grease for my 420?
Thanks,Cooter
Post by Paul Buhler » Thu Mar 30, 2017 12:34 pm
I would use it. My older 350 roll gun had a large diameter piston designed for higher volume-low pressure greasing. Use a gentle approach so as to preserve the roll seals. Good luck. Paul
Post by Stan Disbrow » Fri Mar 31, 2017 5:04 am
Is it a grease or an oil gun? Oil guns do not have push springs and Corn Head grease is just enough too thick for an oil gun.
Pressure is fine, though.
Dang De Bug and my use of contractions! You would think I would know not to use them by now. You would be wrong! :P
Post by Paul Buhler » Fri Mar 31, 2017 7:45 am
A multi-purpose site. We all are learning to write better, and improving our computer skills too.
1954cooter
Post by 1954cooter » Thu Apr 06, 2017 1:27 pm
Seems to work fine with 90wt or regular grease.
Cooter
Post by Paul Buhler » Thu Apr 06, 2017 4:19 pm
Oops wrong thread.
Users browsing this forum: No registered users and 179 guests
