420 Parts on a 440IC?
jd440
Post by jd440 » Fri Feb 09, 2007 11:52 am
Hello,
I have a 1958 440IC that I use around my property. I came across a gentleman who is building one good 420 out of two (~1952), and he will have lots of parts left over. Can I use some of the 420 parts on my 440IC?
In particular, he has a spare engine, lower track rollers, and a rear-mounted winch assembly.
Thanks,
Derek (jd440)
Post by Lavoy » Fri Feb 09, 2007 3:12 pm
The winch should work, rollers will work, engine will work if you torch a hole in the hood to put oil in, otherwise it will not. Plus, if you have a late 440, there will be a HP difference.
Users browsing this forum: Google Adsense [Bot] and 253 guests
