John Deere 2010 steering brake without function
2010Crawler
Post by 2010Crawler » Mon Mar 28, 2016 5:27 am
Hello everybody,
in my 2010, steering brakes are probably stuck. The crawler has been stationary over 15 years, additional water has passed the steering brake into the housing.
This weekend we have built the engine together and we were able to run the chain drive. The 2010 jacked up, which makes the functional testing easier. However, the steering brakes operate the separation of the steering drive translucent to not work, neither right nor left.
Does anyone have an idea?
Excuse my English.
Greetings from Germany
http://raupe2010johndeere.jimdo.com/wie ... riebnahme/
Post by Lavoy » Mon Mar 28, 2016 8:54 am
Most likely the clutches are rusted together. Best bet is to take apart both clutches for inspection.
Post by Tigerhaze » Mon Mar 28, 2016 4:52 pm
I would recommend opening the steering clutch inspection covers and seeing what happens when you put in gear and when you pull the steering levers. These plates are just to the left and right of the seat base. Each cover is rectangular and attached with four bolts.
Post by jtrichard » Mon Mar 28, 2016 8:37 pm
Tiger there are pics in here ( mid way down) http://raupe2010johndeere.jimdo.com/wie ... riebnahme/
they are rusted bad
Post by Tigerhaze » Mon Mar 28, 2016 9:34 pm
I see now- hadn't seen the photos before. Yes probably need to go through the steering clutches.
I would also loosen the tracks some- they look so tight I was half expecting to see a photo of them flying off the undercarriage like a rubber band :lol:
Post by jtrichard » Mon Mar 28, 2016 11:35 pm
2010 the glass bowl and screen goes on the rear (primary fuel filter ) so you can see any water in it
2010Crawler
Post by 2010Crawler » Tue Mar 29, 2016 12:29 pm
The coverings of the steering brakes are probably not oil resistant, right? One could fill the entire case with diesel and soak first. But then when all coverings new need, you have probably done everything wrong
Post by jtrichard » Tue Mar 29, 2016 2:31 pm
DO NOT put diesel/oil in the steering boxes IF there is any thing clutch wise in there that could be reused you will ruin it ..... word to the wise reline the brakes no matter what they look like
2010Crawler
Post by 2010Crawler » Wed Mar 30, 2016 10:57 am
Did I already thought.
I will make it and remove the steering brakes. Before I look for an service manual for the 2010. Unfortunately, the German edition is very difficult to obtain.
Greetings from Germany and many thanks.
Re: John Deere 2010 steering brake without function
Post by Tigerhaze » Thu Mar 31, 2016 10:34 am
2010Crawler wrote:Before I look for an service manual for the 2010. Unfortunately, the German edition is very difficult to obtain.
Have you tried contacting the John Deere bookstore about a German version?
https://www.johndeeretechinfo.com/index ... ductSearch
2010Crawler
Post by 2010Crawler » Thu Mar 31, 2016 11:37 am
Thanks for the help, but there have nothing on 2010
2010Crawler
Post by 2010Crawler » Thu Mar 31, 2016 12:32 pm
What is the correct version of the service manual for 2010?
SM-2037
SM-2034
Who can show me a picture at the right 2010 service manual?
Many thanks
chet
Post by chet » Thu Mar 31, 2016 3:48 pm
sm-2037 ,at least that is the English version
Post by Stan Disbrow » Thu Mar 31, 2016 7:13 pm
So, what is SM-2036 for? Says 2010 crawler tractor. Of course, that means drawbar crawler. No dozer or loader.
Perhaps that is an earlier version? All the early machines SM are for base crawlers, and the attachments have their own manuals. Later machines had manuals which included main attachments. Is the 2010 where that change began?
Post by Stan Disbrow » Thu Mar 31, 2016 7:16 pm
Aw, another double post....
Users browsing this forum: No registered users and 36 guests
