2010 fuel system question
dslkevin
Post by dslkevin » Wed Jan 10, 2007 8:17 am
I bought a 2010 diesel crawler with a bad engine. The man I bought it from started to remove to engine before I got it. I do not know how the fuel lines are to be routed. Can anyone help me out with some pictures? The dozer is a late model.
Kevin
hunter41mag
Post by hunter41mag » Wed Jan 10, 2007 8:29 am
I am not familiar with this setup but most two filter diesel fuel systems are set up the following way.
1. From the fuel tank to your primary filter
2. Primary filter to supply pump
3. Supply pump to secondary filter
4. Secondary filter to injection pump
5. Return from injection pump back to tank or item 1 or 2 above (suction side between tank and supply pump)
It would be a good ideal to get the factory manual for this unit. It would show this information plus any other information you will need later.
I hope this helps.
Don
Eastern PA
440IC
Post by Tigerhaze » Wed Jan 10, 2007 8:39 am
Check the "Show and Tell" forum; I posted you some pics there.
The parts and service manuals are helpful for this; I can also get some more pics of my machine if you need them.
dslkevin
Post by dslkevin » Wed Jan 10, 2007 10:26 am
I ordered a service manual, but it has not arrived yet. I looked at the pics in the show & tell, but my setup is a little diferent.
Kevin
Post by Tigerhaze » Wed Jan 10, 2007 10:37 am
The parts manual may be as helpful, because it provides a detailed schematic of this system as well. I don't remember but the routing may not be shown in that so it is good you are getting the service manual.
The pictures I posted are off a diesel loader; the setup on my loader is very similar but not exactly the same. I wouldn't think the dozer setup is different, but I guess that is possible. I'll try to find pics of my system for comparison and post them.
dslkevin
Post by dslkevin » Wed Jan 10, 2007 2:43 pm
Thanks for the help so far. It looks to me like the fuel comes out of the filter set up and goes around the front of the engine into the injector pump. Another thing, is there is no fuel pump.
Kevin
eastie58
fuel lines
Post by eastie58 » Tue Jan 16, 2007 10:51 am
dslkevin wrote:Thanks for the help so far. It looks to me like the fuel comes out of the filter set up and goes around the front of the engine into the injector pump. Another thing, is there is no fuel pump.
Kevin
kevin on my 64 2010 the lines from the right front tank and left rear of tank come togather at settelment bowl then goes into the double filter setup then around the front of the motor into the top of the injection pump the return line comes off the bottom of the injection pump to the fuel tank at the right rear .the primer line also hooks in with the return line. i m sorry i dont have any pictures but i hope this helps you out
Post by Tigerhaze » Tue Jan 16, 2007 12:05 pm
If you still need them, I will probably be able to get you some up close pics of my 2010 this Saturday.
dslkevin
Post by dslkevin » Wed Jan 17, 2007 1:22 pm
Thanks for the help. I am getting an idea of how its done. Im not sure about the primer. I think Imight have the rest figured out.
If you can get some pics I would appreciate it, if not thanks ok to.
Kevin
Users browsing this forum: Google Adsense [Bot] and 25 guests
