Striker23
Post
by Striker23 » Tue Jan 02, 2007 11:47 pm
First timer And I need HELP. 4 spd tranny tear down, when I removed direction reverser the direct drive gear/shaft did not & will not come off the transmission input shaft. It is stuck tite. Has any one ever had this problem. Or does anyone have any idea of how to remove. Thanks.
- Site Admin
Post
by Lavoy » Wed Jan 03, 2007 10:26 am
It should go, there is nothing that holds it on. Only thing I can think if would be rust, and shouldn't be any of that. See if you can pry on both sides at once, apply some heat, but not too much, and see if that helps.
Post
by Tigerhaze » Wed Jan 03, 2007 11:35 am
FYI-
There is a NOS reverser assembly for the 420 on EBay right now- didn't know if you needed one or not.
Users browsing this forum: Google [Bot] and 31 guests
