4 n 1 bucket for 1010 loader
Post by mini kahuna » Fri Sep 25, 2015 6:25 am
is it fairly straight foward to install a 4n1 bucket on this machine, has a ripper on it now if that matters at all.
all I would be getting would be the bucket and cylinders itself, no control valve or piping.
Post by Lavoy » Fri Sep 25, 2015 7:01 am
As long as you have an aux valve to run it, should not be a big deal.
Post by jtrichard » Fri Sep 25, 2015 8:07 am
The 820/810 loader used on the 2010/1010 used a diverted valve for the ripper/41n1 in the rear of the valve box (see pic #1 here http://www.jdcrawlers.com/messageboard/ ... php?t=7806 ) to switch the second valve from ripper to 4in1 I believe this is the exact valve that was used should be 2 mounting holes in the back panel of the valve box where it bolts in http://www.ebay.com/itm/262059860550?ss ... 1436.l2661 Just different lever and end of spool is threaded on my ( I would have to look at my loader which is on a job right now)
Post by mini kahuna » Fri Sep 25, 2015 4:51 pm
thanks for the info,
I will check out the bucket for sale and see if it is indeed a direct swap for my regular bucket....now if I could just get the track frames of for repairs
1010 loader
Users browsing this forum: No registered users and 262 guests
