1010c crawler distributor timing
Gmcserria93
Post by Gmcserria93 » Thu Aug 13, 2015 8:55 pm
Best way to set the distributor on this crawler. Its back fires though the carb. Help please
gregjo1948
Post by gregjo1948 » Fri Aug 14, 2015 3:48 am
Have you checked the compression? You may have a valve problem. Set the points, loosen the distributor, point the timing light at the mark on the crank pulley or flywheel and twist the distributor. If you have a manual,it will give you the point gap and where the timing marks are located. gregjo1948
Gmcserria93
Post by Gmcserria93 » Fri Aug 14, 2015 6:14 am
Ill check the compression. Just had the head redone the points seem to be in order. Just won't run
gregjo1948
Post by gregjo1948 » Fri Aug 14, 2015 6:40 am
Do you have spark at the plugs and fuel to the carb? gregjo1948
Gmcserria93
Post by Gmcserria93 » Fri Aug 14, 2015 6:50 am
Yep. I have everything. I'm not 100% on the plug wires being right. But it just keeps back firing through the carb.
gregjo1948
Post by gregjo1948 » Fri Aug 14, 2015 7:01 am
If you had the head done, valves shouldn't be a problem. The back fire thru the carb may be the wrong plug wiring sequence. Sounds like it's sparking with an open intake valve. Not sure on sequence, but I'm thinking, 1342. gregjo1948
Gmcserria93
Post by Gmcserria93 » Tue Aug 25, 2015 6:43 pm
Well im pretty sure i found the reason it wont run. Cyl.1 has 30 psi cyl2 has 62 psi cyl3 105 cyl4 105.
gregjo1948
Post by gregjo1948 » Tue Aug 25, 2015 7:06 pm
Lack of compression is why it's not running for sure. The next question is, why the poor compression? If your firing thru the carb, , it's probably not a compression issue. Check valve timing and valve clearance. gregjo1948
Users browsing this forum: No registered users and 281 guests
