# 76 blade
BLS
# 76 blade
Post by BLS » Fri Oct 20, 2006 4:19 pm
Will a # 76 blade fit on a 430C? of so, what else does it fit.
Brian
Post by Lavoy » Sat Oct 21, 2006 9:46 am
If it has been modified, it will fit 40-430, it was designed to fit the 1010 ag, but would fit 1010 industrial and 440.
mikes420c
Post by mikes420c » Sat Oct 21, 2006 5:07 pm
How much modification would it take to mount what looks like a #63 on a 420? I think that is what is on a 1010 in a local parts yard. I already have the blade itself but need mounting arms, cylinders, etc,.
Post by Lavoy » Sat Oct 21, 2006 7:18 pm
#63 came on the 440, I can't remember what it is called on a 1010.
The mounting brackets are designed for a round front crossbar on front, and bolt to a heavy casting on the rear, neither of which is on a 420. It could be done, but will take a fair amount of torch and welder work.
BLS
Post by BLS » Mon Oct 23, 2006 8:55 am
Can you list the Deere blades that came with each modle from MC thru 440, and a general discription. It would be great to know what was available.
Thanks.
Brian
Post by Lavoy » Mon Oct 23, 2006 9:01 am
MC could have been MC1000 tool carrier, and MC60. #61 will fit, but way too front heavy.
40 was #'s 1000, & 1100 tool carrier, MC60, #61, #62 will fit, as well as 602, but real heavy for a 40.
420 and 430 were #61, #62, and 602
440 was #63, #64, and 602
BLS
Post by BLS » Mon Oct 23, 2006 11:12 am
Thanks for the information.
Is this correct then...
MC60 is an inside arm with one hydraulic cylinder.
The # 61 was an inside arm single cylinder (4 way blade).
The # 62 was an inside arm dual cylinders (6 way blade).
Visually, how can I tell the 602 blade from the # 61 and # 62?
Also, what was the P/N of the blade that attaches to the MC1000 tool carrier.
Thanks.
Brian
Post by Lavoy » Mon Oct 23, 2006 1:51 pm
The 602 is an outside arm angle dozer, completely different from 61 & 62.
The dozer blade is an MC100 Bulldozer attachment.
JD40c
Post by JD40c » Mon Nov 27, 2006 9:29 pm
I have a #76 on my 40C (four roller undercarriage) and notice the weight a fair bit when I lift the blade.
1955 John Deere 40C 4-roller
Post by Stan Disbrow » Tue Nov 28, 2006 2:05 pm
Just thought I'd point out that the model 64 blade for the 440 was a power angle tilt blade. Pretty sweet if you happen to have one....
Post by Lavoy » Tue Nov 28, 2006 4:49 pm
I have a #64, it is in pieces to be restored, kind of like the crawler it came on, but hopefully in the next 20-30 years I get it done.
lavoy
ggfossen
Post by ggfossen » Tue Nov 28, 2006 5:49 pm
Mine is a Holt blade with outside arms, manual angle, and manual rotate. Would it be much like the 602?
I know that it was on the crawler from only a few years after manufacture, so it probably was built for the 420? Serial numbers are still visible. I think they are different for the blade vs the mount.
Gary.
Users browsing this forum: Google Adsense [Bot] and 251 guests
