I'm having trouble tracking down parts for a blade that is identical to this one in the picture
http://www.jdcrawlers.com/messageboard/ ... 4f434e3488
the parts that I need are listed for a 615 on the jd pdf parts however I cant find the parts for the part numbers listed I need the main pivot pin and bushings or is there an alternative repair method you use mine is a little worn and causes the blade to bite/pivot downward when pushing.
JD 440 blade
Correct, if you have a power 6 way on a 440, it is a #64.
