Engine Swap
astro57
Engine Swap
Post by astro57 » Fri May 16, 2014 3:53 pm
Hi all, new to the site. I just purchased a property that came with a 420 crawler, 1957 I think, no serial number. It had antifreeze in one cylinder, upon further inspection I found a crack in one cylinder. I will likely fix that but in the mean time I am wondering if there is any readily available engines that can be swapped into this machine.
Thanks, Dave
Post by Lavoy » Fri May 16, 2014 5:00 pm
Do you mean another 420 engine?
astro57
Post by astro57 » Fri May 16, 2014 5:39 pm
Lavoy wrote:Do you mean another 420 engine?
No, I hope to sleeve and rebuild the original engine. I just wondered if there was something else more modern to bolt up with or without an adapter plate so I can use the dozer for now. Hopefully the rest of the machine is operational, I am told that it is.
Post by Lavoy » Fri May 16, 2014 7:47 pm
By the time you cobbled anything modern, you will spent more time that it will take to rebuild the one you have. If you don't want to rebuild yours, I have a long block here that came out of a good running crawler.
Cletrac68
Post by Cletrac68 » Sat May 17, 2014 8:44 am
I always wondered how a Kubota 3 cyl. diesel would power these old crawlers.
Post by Stan Disbrow » Sat May 17, 2014 6:12 pm
Pretty much the same as the 3 cyl diesel powers the 350..... ;)
gregjo1948
Post by gregjo1948 » Sun May 18, 2014 7:32 am
Too much power leads to too many broken parts! gregjo1948
Users browsing this forum: No registered users and 52 guests
