reverser only works in reverse?
Reverser
The cost to to rebuild a reverser obviously depends on how much damage
you need to repair.If you already have the coupling then a shaft would be
a lot cheaper.Everything in the reverser is Deere only and I priced one
cross shaft in the differential at over $180.00.If you keep the internals
from the reveser you can always go back to it as time and money
allow.There is always a market for the internal parts so don't just
scrap them.Luck,JimAnderson
The reverser has been shifted without using the foot clutch first. Between this and not changing or maintaining oil level I would say has caused the lion's share of bad reversers out there.
I personally would not take a reverser out unless it was catastrophically destroyed, and even then I would still likely look for used parts.
I have the clutch discs on hand, check the rest of the reverser for damage, replace front and rear bearings and seals, put in new discs and you should be ready to go.
Properly operated and maintained reversers are pretty much trouble free.
Clutch discs are $80 each, I have one set on hand, and maybe one extra.
Not that I know of at this time.
- steamfitter99
Reverser
The reverser is really a simple device quite ingenious. However the weakness was the tabs on the clutch disks getting sheared off. This was not only caused by shifting the reverser with out clutching but also by letting the pressure to engage the clutch pack to get too light and the clutch slip until it hits the tabs. The differential parts also has spider gears and each of these has a shaft and needle bearings. It also has a very specific procedure to follow for rebuilding the entire assembly. Get a manual and look it over and see if it is something you want to tackle. If the shafts are torn up or the bearings are smoked then the price went up substantially. If it is only clutch disks that is not too bad. If you have ever ran a crawler without a shuttle or a reverser you can get used to it. If you have a lot of work to do then it is almost required. If you need disks buy them from Lavoy. I do know this the disks are the same as the clutch pack JD used to engage rear PTO's on some of their tractors, the 1010 being one of these. I have taken the disks from some of these clutch packs and used them on the reverse side of the reverser. Tom.
i just got the longer shaft, coupling and spring i needed . i got it for a deal i could not say no to. i drilled my transmission so i could put my 3/16 roll pin through to secure my coupling today. the only thing i am not sure about is in the front of my reverser housing there is a circular plate that bolts on and on the inside of that plate there is a spot where my bearing on my old shaft would fit into that kept everything in place and centered in my reverser. well my new shaft which is the right john deere shaft i needed. does not have a step in it for me to install a bearing. is this right? was there no bearing on these shafts when they came from deere like this?
Users browsing this forum: No registered users and 235 guests
