Air filter clamp
- bob lavoie
Air filter clamp
I have a 440ic sn 448280. I need the clamp that hold the oil bath onto the bottom of the air cleaner assembly. Deere says its an obsolete part and cant get it. Found a steiner part number of JDS541 but it says for sn prior to 448000. Any got any info?
Bob Lavoie
1959 440 ic
1959 440 ic
- DukeofDeere
- DukeofDeere
Air cleaner is larger diameter on the later crawlers. I stock the Steiner clamp, it is too small.
- DukeofDeere
Re: Air filter clamp
Did you find a clamp?bob lavoie wrote:I have a 440ic sn 448280. I need the clamp that hold the oil bath onto the bottom of the air cleaner assembly. Deere says its an obsolete part and cant get it. Found a steiner part number of JDS541 but it says for sn prior to 448000. Any got any info?
I found a guy with some new old stock parts.
He may have one if you need.
Duke
Users browsing this forum: Google [Bot] and 11 guests
