The top two cylinder's on my loader are leaking fluid.
They are the short one's, with the 2" diameter ram.
I took them apart to replace the seal's.
I can't get the cylinder to compress, is this due to the safety valve?
If so how do I get that valve out of there?
I have them off the dozer, so I could hook-em back up and suck the cylinder in, but is there another way? I could stand on these ram's, and they won't go in.
420 loader/crawler hydraulic question
No safety valve, something is stuck.
420 hydraulic question
Well, they are both sitting on my bench.
Nothing hooked to the dozer.
You'd sure think they would collapse.
420 loader/crawler
I put some o-ring lube on the cup before installing. Occasionaly they still require some beating. gregjo1948
Users browsing this forum: Google Adsense [Bot] and 28 guests
