Roosa-Master pump bench tested..
royboy
Post by royboy » Tue Oct 09, 2012 10:53 am
Any ideas on where to get a injection pump bench tested and how much it cost????
Thanks,
royboy
gregjo1948
Roosa-Master bench test
Post by gregjo1948 » Fri Oct 12, 2012 6:11 am
If you don't have a dedicated pump shop, try truck stops,truck dealers, tractor dealers, and etc. . Greg
royboy
Post by royboy » Fri Oct 12, 2012 6:18 am
thanks,
Post by Paul Buhler » Fri Oct 12, 2012 9:20 am
Give these guys a call - they may be able to help you or help find someone closer to you.
Good luck
Burlington Diesel Pump Repair
559 Industrial Avenue, Williston, VT
(802) 864-4880 ‎
royboy
Post by royboy » Fri Oct 12, 2012 7:26 pm
Thanks for all the help...
royboy
jdemaris
Re: Roosa-Master pump bench tested..
Post by jdemaris » Tue Oct 16, 2012 3:00 pm
royboy wrote:Any ideas on where to get a injection pump bench tested and how much it cost????
Thanks,
royboy
In any pump shop I worked in - it was standard policy to never mount anyone's pump on the test stand unless we had it apart first (and worked on it). Many consider it too risky to install a pump in unknown condition on a very expensive test bench. It's also takes a bit of labor. Half the time spent in pump repair is mounting on the stand and testing.
Some tests you can do yourself pretty easy. What exactly are you trying to find out? If it's injecting, timing advance?
Users browsing this forum: No registered users and 163 guests
