440 icd late model air cleaner
440icd
Post by 440icd » Thu Jul 06, 2006 9:34 am
I have been welding up holes in the base of my old oil bath air cleaner for this 2-53 detroit.
I was wondering if I can get some type of air cleaner that has an eliment instead of this old type oil bath aire cleaner.
where can I get it?
is there a specific model number?
how much do they run?
thanks
scott
Scott in wa.
Post by Lavoy » Thu Jul 06, 2006 9:43 am
Nothing that I have ever heard of or know of.
440icd
filter
Post by 440icd » Thu Jul 06, 2006 11:57 am
Has enyone ever switched to a non oil bath type are cleaner for there dozer???
I bet someone has..??
some type of eliment filter type.
thanks
scott
Scott in wa.
shinnery
Post by shinnery » Thu Jul 06, 2006 2:54 pm
When I bought my 440ICD/831 the air cleaner was missing. After searching around for a while one diesel shop suggested to me that I should look into a throw away filter. I am running a Baldwin PA2803. It is a pleated paper filter about 8" in diameter and about 10' long. Came complete with a metal outer shell and a rubber gromet for an outlet fitting. I took the filter to a local muffler shop and got a piece of exhaust tubing about a foot long. It fit perfectly into the filter and they expanded the other end to fit the rubber elbow that comes off the blower and replaced the steel tube that ran to the original filter. The filter lays sideways right beside the fuel tank in the area the original filter used. I built a bracket out of 3" angle iron that mounts to the two bolts that mount the fuel filter. The other arm of the angle iron supports my new connector pipe. About $20 for the filter and a couple dollars at the muffler shop. So far so good.
Howard Yoder
Post by Howard Yoder » Sun Jul 09, 2006 7:27 pm
I have one that some one had put on a 1010 that they also put a 253 in and it mounted on the fender don't know what it come off of originally. I'll be busy this week with our local stem show but if your interested get a hold of me next week and I will send you a picture of it.
440icd
air cleaner
Post by 440icd » Mon Jul 10, 2006 1:17 pm
Hey thanks for the info,
I fugured that some one must have done this.
Do they work ok????
I ended up having to jb weld, tried welding but its so thin and its tough to clean and always ending up with holes that I can't see, smaller that a pin.
I will need to change it out this fall. with somthing else.
I want to go with a filter somthing like you guys have done, or have.
thanks
scott
Scott in wa.
Users browsing this forum: No registered users and 341 guests
