40c engine main bearing cap direction
rooster
Post by rooster » Wed Mar 07, 2012 7:59 pm
Could someone tell me what direction does the main bearing tabs go on a 100cid jd
Towards the cam or not. The engine I tore down had the tabs opposite to the cam, is this corrrect
Dave T
Post by Dave T » Thu Mar 08, 2012 2:43 am
Is there not a tab relief in the block ? Or an oil passage that will determine direction?
rooster
Post by rooster » Thu Mar 08, 2012 8:23 am
There is a tab in the block opposite to cam side. There is a tab in the main cap also. But the question is what side does the tab in the main bearing cap go since you can flip the main bearing cap etheir direction. Origanlly they were opposite to cam..
waterman28
Post by waterman28 » Thu Mar 08, 2012 12:17 pm
Tab to Tab I believe
JD 1010 Crawler
Ferguson TO 30
Case 580C
996 David Brown
Dave T
Post by Dave T » Thu Mar 08, 2012 5:20 pm
Yes tab to tab at least on any eng. I've ever rebuilt. the tabs keep the bearings from spinning on both the mains and rods. tab to tab keeps the bearings in place no matter the rotation. Pay close attention to the oil ports in the bearings that they match up with the oil passages in the block for the mains and cam bearings.
Post by Lavoy » Thu Mar 08, 2012 6:42 pm
The only thing that goes towards the cam is the dimples on the connecting rods, main bearings are as previoiusly described.
Users browsing this forum: No registered users and 247 guests
