Model 62 blade
deereboy89
Model 62 blade
Post by deereboy89 » Sun Jan 15, 2012 5:26 pm
So im looking at a john deere 420 with a model 62 six way adjustable blade. Its hydraulic only on the up and down. Would it be really hard to make the pitch hydraulic on it??
DukeofDeere
Post by DukeofDeere » Sun Jan 15, 2012 6:21 pm
Is not too big of a project.
Some welding...
A 2 way cylinder...
Another control valve.
Just takes some time and money.
Just saw it done on a 1010C.
Duke
Post by Lavoy » Mon Jan 16, 2012 9:31 am
No, not really that difficult, but the piece that slides was never meant to used that way, and pretty much for every one I have seen done, they eventually break the tabs off, then it is just a paper weight.
deereboy89
Post by deereboy89 » Mon Jan 16, 2012 9:52 am
Well maybe the best idea is to leave it be and just jump off the tractor then. Thanks Guys
Post by Paul Buhler » Mon Jan 16, 2012 12:42 pm
Hi: I leave a 2lb sledge and a small crowbar in the crawler belly pan below the generator for convenience to make these adjustments. I put a bolt through the wedge so it doesn't get lost when I smack it loose. There is a blade level mark ( 1/4" dimple") on the semi-circle which helps with adjustments.
I saw elsewhere on this site pictures showing a nice solid partial conversion of a 62 blade to PAT which used a center pivot - I can't remember the topic is was shown under or who shared it - maybe someone can give a link.
Good luck. Paul
doc40c
4-way hydraulic blade conversion
Post by doc40c » Mon Jan 16, 2012 6:11 pm
hi deereboy89, look in the show and tell section for feb. 12, 2011 by doc4oc and you will see a link to the pics of my crawler with the conversion you may be interested in. if you have any ? let me know. the conversion has worked very well and i haven't broken any parts ! yet! and i don't baby my machine but i do know it's limitations and use it accordingly. good luck! Randy from Michigan.
Post by Paul Buhler » Tue Jan 17, 2012 1:45 pm
Found this:
http://www.jdcrawlers.com/messageboard/ ... tilt+blade
Willy shows other pictures of the back of his blade when he was building it on the picture hosting site. Maybe he'll share his thoughts. Paul
Willyr
Post by Willyr » Fri Jan 20, 2012 5:36 pm
LOL I will trade my crawler with 6 way blade for a rubber tired Deere. Some reason crawlers cant participate in parades.
The only real draw back that I encountered when I made the 6 way is I used a 3 inch cylinder on the twist. It needs to be much larger. When I twist the blade in the air and then set it back on the ground, if I use any down effort the cylinder wont hold the angle.
However that being said. I can when moving forward slowly drop the blade and it will stay the angle set as long as the tractor is moving.
One of these days I will post a video of the blade going through its paces.
former owner of a 1956 420c
Post by Ray III » Sun Jan 22, 2012 7:57 am
You mean blade tilt, pitch is moving the top of the blade forward or back to adjust how aggressively the edge cuts, which small crawlers don't have.
I also want to convert my 62 to hydraulic tilt someday. Not that it's hard to do but you really need the ability to tilt the blade on the fly to make contours easily. Lavoy is right about the tabs not being strong enough but they have already been welded on and I figure if I replace them with a single piece of curved square stock it will be much stronger. Make sure you add grease fittings.
Pat
Post by Pat » Mon Jan 23, 2012 9:09 am
If you want to save all the re-engineering, I have a 64 blade with all the goodies that I will part with. PM me.
Willyr
Post by Willyr » Tue Jan 24, 2012 3:32 am
Ray III wrote:I also want to convert my 62 to hydraulic tilt someday. Not that it's hard to do but you really need the ability to tilt the blade on the fly to make contours easily. Lavoy is right about the tabs not being strong enough but they have already been welded on and I figure if I replace them with a single piece of curved square stock it will be much stronger. Make sure you add grease fittings.
For what it is worth. I found you need to put a rubber flap aver the joint where the pivot is. For me there is a lot of dirt that will come over the top of the blade and fall down on the back.
cat10til2
6 way blade
Post by cat10til2 » Tue Jan 24, 2012 9:04 am
I solved all of the problems by using the push frame and lift cylinders for the manual blade. I cut off all the parts in the front and welded in a power 6 way blade off of a case tractor. The fit was amazingly close and it works great. I had to add an extra valve to control the tilt for the blade. I might be able to post or send some pics if anyone is interested. One big difference that I notice is that the case blade is a few inches shorter than the JD blade was.
JD 1010, 610 blade, winch, gas
1968 case 530 CK, 1946 John Deere A, 1928 Ford Doodlebug, 1969 Minneapolis Moline with West forklift attachment
Post by Paul Buhler » Tue Jan 24, 2012 2:28 pm
cat10til2: I for one always enjoy seeing pictures of someones "problem solving" and solutions. Thanks for the offer. Paul
cat10til2
pics
Post by cat10til2 » Thu Jan 26, 2012 6:01 am
Hi Paul- My home computer has been down for the past few days and it has the pics on it. I will try to post them once the computer is back up and running.
thanks
cat10til2
pics, I hope
Post by cat10til2 » Mon Jan 30, 2012 4:51 pm
here are some pics of the case blade that I put onto my JD1010. The pushframes are original to the JD, all else is Case. Pic. number 2 shows how I cut away some of the inside of each push frame to make the correct opening for the Case frame. I added some triangular pieces for strength. Hoses are still routed through the frame. I did have to add one more valve to control the tilt of the blade.
I also drilled holes in the Case blade and bolted the 3 piece JD cutting edge to the botttom. It works great so far. It has been done for about 1.5 years.
Users browsing this forum: No registered users and 217 guests
