No Master Link?
CharleyF
No Master Link?
Post by CharleyF » Sun Nov 13, 2011 6:50 pm
I was looking at the left track on my 2010 today because I know I am going to have to replace the clutch pack on that side. I do not see a master pin in the track at all. The other side is obvious, there's a bolt in it. However, all the pins are identical on the left side, inside and out. I do not see a circlip or any other device suggesting anything other than a press fit pin.
Say it isn't so? this won't be fun if it is....
- Charley
Pammark
Post by Pammark » Mon Nov 14, 2011 9:33 am
My 2010 masterpin head is round and flat, but with one round side flattened off. It fits into a slot on the track. Take a look at my post "2010 Repair" and you can see how I derailed the tracks to get them off. Then I could man-handle them on the ground to remove the pin. Also see how I removed the pin.
I suppose if your tracks truely do not have a masterpin, then I guess you could re-rail the tracks in the reverse order to put them one. Just remember there is a correct direction of rotation of the track.
Mark
JD 2010 Crawler with Loader
CharleyF
Post by CharleyF » Mon Nov 14, 2011 8:33 pm
Thanks Mark,
I'm familiar with your series ( it's really good) but I hadn't looked at it from the master link point of view. I'll go look at it.
I had kind of resigned my self to derailing the track the way you did. I just need a bit more time. I looked at the garage of the place i just bought and it's big enough to put the dozer in while I work on it which means I can do it this winter out of the cold and snow which is just around the corner.
- Charley
Post by Lavoy » Tue Nov 15, 2011 9:08 am
There is a possibility it has replacement aftermarket rails which use a drive master pin. Look at all of the pins, one may have a small "dimple" in it, if so, that should be the master pin. The other thought I have, is it a late crawler so it has 350 rails, again, may have a drive master pin.
CharleyF
Post by CharleyF » Tue Nov 15, 2011 11:43 am
Thanks Lavoy,
It is an early model but the undercarriage has been replaced and is in nearly new condition. I think I did see one pin that had a small dimple in it, i'll look again this week if I can get home before the sun sets.
- Charley
Post by Paul Buhler » Tue Nov 15, 2011 12:33 pm
There are a few pictures on the site showing how people use a 2x4 with a hole in it clamped to the tracks to hold the drift in position for master pin removal.
for example:
http://www.jdcrawlers.com/messageboard/ ... in+removal
see near the bottom of page 1 on Mark's thread
I use a clamped 4x4 and a big hammer with the pin located over the sprocket or front idler depending on best access. Good luck. Paul
CharleyF
Post by CharleyF » Wed Nov 16, 2011 7:04 pm
Thanks Paul. Looks like I will have to do all of what you did on the left side.
Charley
- Charley
Post by Paul Buhler » Wed Nov 16, 2011 10:10 pm
I was only a spectator - I just shared Mark's detailed efforts with you. He gets the credit for teaching us all a few useful tricks. Paul
Users browsing this forum: Google Adsense [Bot] and 200 guests
