1960 jd 440 crawler loader
I need to find a website to download tech data for my jd 440 loader. also
the tranny wont go into gear while eng. is running. i know the tranny is good because i can jam it into 1st when i idle it low. is there a clutch and pressure plate set up like there is with a regular vehicle with a standard system.
moveitall haulin
Yes it is a regular clutch set up. Do you have a reverser on it? If you keep jambing it into gear you won't have a good tranny for long. More than likely if it has been sitting for a while the clucth is rusted to the flywheel. If you do have a reverser it will have a lever on the left side of the dash and you can put this in nuetral and put it in gear and use it like this for a while to see if the clutch breaks loose but more than likely you will have to pull the engine. Good Luck
I dont rmember a lever on the dash, I will look when I get back home. there is a lever on the left side of the shifter, mounted on the tranny. the tranny is a 5 speed with reverse. I got a quote to replace the clutch and pressure plate of about $800. It sat up for 8 years before I got it. Every thing eles works great.
moveitall haulin
my crawler
Checked and no reverser. it has the shift rod running throught the dash, not connected, i suspect that was a standard issued part. I went ahead and took it to the repair shop. he is going to pull the clutch assmbly and have it rebuilt. parts will be about $350. John Deere has the clutch parts but the clutch disk alone is over $500.
I also need to find a cheap place to buy trac treads. JD wants $50 a piece
moveitall haulin
1960 440
Lavoy, I called the shop and they have already replaced the clutch. they didn't get the new on there is a place here in jacksonville that rebuilds them so they went that route. He onoly need to find a bearing now.
moveitall haulin
60 crawler
crawler is up and running. right side trac is loose. tried putting greese in but its not moving. must be missing something here
moveitall haulin
Users browsing this forum: Majestic-12 [Bot] and 10 guests
