JD 420 Crawler Alternator
Wow - check it out .. he's not saying its OEM though!
http://cgi.ebay.com/JOHN-DEERE-420-CRAW ... 5d2f3dd939
If man can break it man can fix it .. it just takes time and money.
- JD440ICD2006
- JD440ICD2006
If you run a generator bracket on a two wire double belt pulley alternator, will it make the ammeter needle spin?
Well the belt adjuster bracket sure looks like a 420. The home made mounting brackets look close to what I built as well. Sure not factory but for someone who is wanting to do the conversion most of the work is done for them here. Not my auction. I mounted a single wire delco on my 420. I'll get some pictures posted.
C. Enyeart
- JD440ICD2006
For a common tractor that I was just going to use, I may consider an alternator.
But for any of the classics, an alternator is like a booger on your face. It kills the value and they are ugly.
Generators are easy to work on and rebuild, parts are available, and they put out enough power if you run the engine at rated speed.
Users browsing this forum: Majestic-12 [Bot] and 12 guests
