jd 2010 running issues
fires up and runs fine for 15 to 20 minutes, then starts to spit and sputter and then eventually dies. I changed the fuel filters and still does the same. it is diesel..any recommendations would be greatly apreciated.
I wanted to add that when it starts acting up the rpms start to drop off and when I give it more throttle it does not respond, rpms keep dropping off until it stalls. Ive cleaned the air filter and replaced the fuel filters....dont know what to do or check next.
On a JD440 diesel, there is a linkage rod from the governor to the injector rack and I assume there is something similar on the 2010. If you move that rod up manually are you able to get the engine to rev up? If it will rev, then you are likely dealing with governor problems.
- RedDirt
I had a roosa master pump on a Case 480 of similar vintage do this. Found loose broken plastic parts in the pump that were messing up the whole operation of the pump. There are some inspections you can do for this via some of the removable ports on the pump. You really need a manual, a clean pump and lots of caution to open this up, there are springs and loose parts potential. The JD manual on Roosa master pumps is very good, it's number is SM2045.
RedDirt - 2010 Diesel Crawler Loader Drott 4in1
There are quite a few posts from JDEmaris on this subject. Basically there was a plastic ring in those pumps that wears out over time and disintegrate. The resulting debris looks like mouse turds.
I would suggest you search for "mouse turds" in the search menu above and read those posts for more information.
Fuel Issues
I would check both the fuel return line and also the return line fitting coming out of the injection pump.
Had similar issues on a few engines. Very frustrating to find the real issue after installing a different injection pump.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Free Deere Tech manual for injection pums
There's a webpage right now that has the expensive Deere Roosamaster/Stanadyne manual available for download free. Get it while you can. It's in a 214 megabyte PDF file.winnerjd2010 wrote:just started tearing into pump, lots of "mouse turds". Really need info on how to disassemble the pump. I saw JDmaris had picks of disassembling a pump but most of the pics have been removed. a diagram would be great. any help would be greatly appreciated.
thanks
Go the following, and then click on, and download IP.PDF Just keep in mind it's big and won't work well if you're using dial-up.
http://www.getdieselpower.com/misc/trac ... IP_Manual/
Thanks JDEMARIS. I downloaded the roosa master manual. My next problem is that I cannot even complete the 1st step in disassembling the pump. It says to pull out the pump drive shaft, should pull right out but i cannnot get it to bugde. Im afraid to use too much force in fear of breaking something...anyone ran into this issue or have suggestions?
The pump has to come all part to replace that plastic ring.winnerjd2010 wrote:Thanks JDEMARIS. I downloaded the roosa master manual. My next problem is that I cannot even complete the 1st step in disassembling the pump. It says to pull out the pump drive shaft, should pull right out but i cannnot get it to bugde. Im afraid to use too much force in fear of breaking something...anyone ran into this issue or have suggestions?
The reason why the shaft won't come out is because you have a vertical-mount pump and not a horizontal. Verical pumps have a retainer to keep the shaft from falling out. Horizontal pumps don't. Vertical pumps are designed to come off the engine with shaft staying in the pump (like used on 1010s, 2010s, 2520s, 3020s, 4020s, etc.). Horizontal pumps are designed to come off the engine with the shaft staying with the engine (like used in 1020s, 2020s, 350s, 450s, etc.).
Users browsing this forum: Majestic-12 [Bot] and 14 guests
