1010c main drive clutch
looking for input on drive clutch on 1010c gaser. clutch was stuck. took it apart and there is about 1/8th inch of friction material left should i put the money into it? and what are the measurements of the pressure plate set tool?
If I was that far into the machine it would get a new clutch disc, pressure plate, throw-out bearing, and a pilot bearing. The condition of the surface of the flywheel would determine if I had it faced or not.
Anyway the amount of friction material you have left on the clutch disc sounds really thin to me. Replace the above mentioned parts and have peace of mind that you won't have to do it again anytime soon.
As to the dimensions of the setting tool I can not help you with that.
Welcome to the sandbox
Dan
Dan
1956 420C with GSC blade
Users browsing this forum: Google Adsense [Bot] and 257 guests
