Loading a dead crawler
- DiggerLarry
- Contact:
Guys,
Looking for some opinions/tips on loading a dead crawler that has one side locked up. I have pushed or come-a-longed them on my trailer before but those were free and rolling. I'm thinking I could jack it up and put a 2x8 under the locked up track and then pipes under that to get it on. Coming up the ramps might be the tricky part due to the change of angle. Anybody got some ideas?
There are small devices that millwright machinery movers use to move heavy equipment they're about foot long,8 inches wide and 6inches tall they look like a small set of dozer tracks they work very well in a straight line one under each corner
- lastchancegarage
Digger,
The 2x8 might work better than you think. I recently went to pick up a small crawler with two locked tracks. I jacked up the tracks and put 2x6's under them with the same thought of rolling pins under the boards to roll it onto the trailer. Funny thing was, the tracks bit into the 2x6's and they ended up being skis for the crawler. We left them under the tracks once it was on the trailer and when we got home, backed up to a tree, chained the come alongs to the tree and crawler and skidded her off the trailer. One other thing, at a couple of times along the way I used my floor jack to relieve some of the pressure on the tracks. Worked pretty well. The only thing better would have been an electric winch on the trailer, but otherwise things worked out well. Another factor is the size of the machine. The tractor we loaded was an ATC GT-30. I don't know how this would work with my 440 ICD. Good luck.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
Howard Yoder
If you have someone close with a tilt bed truck and winch on it check and see how much he will charge you I luck out one time and the guy didn't charge much at all but that has been a few years ago. Good Luck P.S. the grease between 2 piecies of wood works good just make sure it don't ge away from you when it's half way up or even on the trailer.
- DiggerLarry
- Contact:
Thanks for the ideas and advice. You guys are great. I'm going next weekend to get it. I'll take a varity of the things mentioned here and we'll see what happens. I got to thinking I might jack up the front and back the trailer under it up to the front idler. At least that way it is half on when I start. I never thought it would skid as easy some have experienced. I'll let you know how it goes.
- DiggerLarry
- Contact:
Just to let you know, it was a peice of cake. I didn't get to try out any of the suggested methods even though I showed up in the Boy Scout way with a truckbed full of blocks, boards, grease, pry bars, big honking come-a-long, chains and another strong back.
The fellow had a little skid-steer and picked the front up. I backed the trailer under it. He got behind it with the skid-steer, picked the back end up and just shoved it up on the trailer. I was out in under 30 minutes. I was surprised how much that little skid-steer would pick up.
I got it unloaded at home much the same way using the Ford tractor and loader. I already have it running and freed up but it's little more that a parts machine. Thanks to all for the ideas. I'll remember them for next time.
