420 C specs
trctdon
420 C specs
Post by trctdon » Sat Mar 11, 2006 2:03 pm
Hello guys, new to this BB, usually over on the Cat BB's Am looking for the torques for the rods and mains, also rod and main bearing clearances and the cylinder head torque. If someone could provide this info for me i would appreciate it. I thought that i had this info but can't seem to find it I could go by bolt size but would rather go by JD specs. Thank you, Don
JD40c
Post by JD40c » Sat Mar 11, 2006 7:05 pm
You might list which model of crawler you are working on.
1955 John Deere 40C 4-roller
ole frank4491
Post by ole frank4491 » Sat Mar 11, 2006 8:10 pm
torque for rods-55-60 lbs. mains-140 lbs. head -85-95 lbs. oil clearences -.0010/.0035. this info. from 1971 federal-mogul engine bearing catalog and shop manual ole frank4491.
trctdon
Thank you
Post by trctdon » Sat Mar 11, 2006 10:47 pm
JD 40Che post subject was for a 420C i somehow i had 420C in my head, it is actually a 430C.
Ole Frank 4491, thank you for the specs. would i be correct in assumeing these specs would also apply to the 430C. Thanks, Don
ole frank4491
Post by ole frank4491 » Sun Mar 12, 2006 7:59 am
these specs. are good for 420, 430, 440. ole frank4491
trctdon
Post by trctdon » Sun Mar 12, 2006 11:33 am
Thank you very much. Don
