440 blade and 1010 blade
can anyone tell me what the difference is between the outside blade on the 440 crawler and the outside blade on the 1010 crawler? Will the parts catalog for the 1010 blade be the same as the 440 blade or is everything different?
- JD440ICD2006
The factory outside blade on the 440 is a Model 602. Do you know the model number of the blade that you have?
- JD440ICD2006
Merely a guess, but I believe some of the base parts could be the same, but some may very well be different, especially if it is the later blade with tilt that Lavoy mentions.
The Model 602 has hydraulic lift, and 25 degree angle either side. There is no tilt on the factory 602 blade.
These are later outside mounting bulldozer applications from John Deere.
BULLDOZER___CRAWLER__YEAR
616_________1010______1962-1964
624_________1010______1960-1962
625_________2010______1962
626_________2010______1962-1964
Dave
The inside mount 6-way blade for a 440IC is a model 64. I recently bought one and it will probably replace a 831 loader on one of my 440ICDs. If I decide the 440IC is salvageable I might just replace the 602 on it as an easier conversion. The 64 has a S/N Plate near the center pivot, I will have to look at this one to remember exactly where.
