motor
motor
come on guys some body must have run across some info on what john deer used the 115cid engine in the engine in the dozer has to have the liner plate replaced it cant be rebored new one from johndeer is 750.00 just to get the engine ruuing going to cost over 2000.00 to get it runing
This thread is specific to swapping for the larger 2010 engine, but may give you some ideas for the 1010:
http://www.jdcrawlers.com/messageboard/ ... ht=combine
motor
thnks for the info Lavoy if i know what the 115 cid engine is in i might be ably to get the motor cheap and have the parts i need thanks for the help will keep posted how things work out thanks again
I don't know if it will be any easier to find good 2010 engines (145 cid gas), nor if it would fit easily in the 1010 frame or bolt to the transmission bellhousing. I assume you have the gas engine since you mentioned you had the 115 cid block.
I found a catalog that cross-references most of JD's engines for all of their equipment (ag and industrial). This is a handy link for engine specs regardless of model.
http://endurancepower.com/media/CATALOG_JD.pdf
If you scroll towards the bottom of the discussion link I previously posted, JdeMaris mentioned a block that could fit both 1010s and 2010s (155 cid) that was sleeveless. You may want to look into that one.
Users browsing this forum: No registered users and 204 guests
