What were the hydralic pressure for the 1010? Were they 2000# or same as the johnny poppers? Or were some made with each?
Ray
Not a crawler but a question about the 1010
ryan_marine
430C, MT, D, 5 A's, B, BR, BI, MT, LA, L, 2 H's, 2 G's, 320S, 40T, 40S, 430T, 430W, 440, 530, 620, 720, 730S, 830, and 4020.
- Tiny Crawler
closed or open center ?
Probably closed center the open center did not start showing up untill the 310,410 backhoes in1975 I think you need a veriable displacement pump for opencenter systems?I don t think the small dozers had this till the G series loaders in 1987so your backhoe should fit right on Most of these old deeres did not have enough pump capacity so it might be a bit slow My 1979, 550 dozer got a bigger pump for the back hoe and I still was not able to multyfunction the hydraulics but the blade was lightning fast I guess that meens that hoes are specked to there pumps so the 1010 may be a slow supplying the oil But if the price is right it is batter than shovleing!!digitup
Variable displacement pumps are used on closed center system, gear type is most common on open center. On the ag tractors, Deere changed most of the larger row crop tractors to closed center in 1961 with the introduction of the 10 series. Given the cost of the closed center system, I don't believe they used it on anything smaller than 3010. Even today, the 5000 series is open center while the 6000's on up are closed center. One exception may be the Advantage series tractors that use a load sensing open center system.
