Hello all, I need a little help on the following questions.
I'm putting the steering clutch assembly back together in the clutch housing.
The manual is vague on the issue of the throw-out bearing sleeve.
Are you supposed to press the sleeve into the differential?
Also can anyone tell me if the bearing that holds the shifter in is a true bearing of some type or just a cup with a snap ring?
And what does the spring attach to after you slide it over the shifter rod?
Again the manual is vague on this issue.
Thanks in advance.
Craig
440 Steering clutch
Thanks Lavoy,
I found that dimension, it was in the spec. part of the manual. I just didn't read far enough.
So you wrap the spring around the shifter and attach one end to one side of the cover and the other end to the other side of the cover, right!
That way the shifter finds neutral when not in gear.
Craig
Craig
