gm deasil
switchhappy
gm deasil
Post by switchhappy » Fri Mar 06, 2009 8:54 pm
how do i see what motor i have.. im thaninking it is the 2-53, well thats what head gasket fit it, but the book shows a hand hole on the block and a vent tube, well mine dont have neather.. so is it mabe a 3-53?? what is the difference???
350c 6 way blade, winch, log arch,,, current 3 year project of being saved and put backgether.. HELP
jclem40c
Post by jclem40c » Fri Mar 06, 2009 9:14 pm
:? if its got 2 cylinders (2-53) and tracks its a 440 icd if its got 3 cylinders (3-53) and wheels its a pettibone skidder. Mother Deere,to the best of my limited knowledge never used a 3-53 in nothin.
2 Tractors
1 Crawler
1Wife
1 Kid, uses the most fuel
3 grankids
jclem40c
Post by jclem40c » Fri Mar 06, 2009 9:16 pm
:? if its got 2 cylinders (2-53) and tracks and burns fuel oil its a 440 icd if its got 3 cylinders (3-53) and wheels its a pettibone skidder. Mother Deere,to the best of my limited knowledge never used a 3-53 in nothin.
2 Tractors
1 Crawler
1Wife
3 grankids
switchhappy
Post by switchhappy » Sat Mar 07, 2009 7:15 am
ok mine is a 2 cylender, but i cant figure out why it dont have the hand hole on the side of tge block and why i cant find that air box drain tube?? my manual shows it by the dip stick on the left side/"if sitting on the crawler" ok my dip stick is on the right side with the blower?? tell me that one???
shinnery
Post by shinnery » Sat Mar 07, 2009 11:52 pm
I have read somewhere that the inspection hole was deleted by GM during the time these engines were built. My parts manual PC-609 with date Jan-66 on pages 10-2 & 3 shows the cover was only used thru s/n 2D 4009. The drain tube apparently changes length at 2D 5160 from 14-3/8" to 2-7/16". It should be under/behind the govenor assembly on the left side of the engine if you were seated on the seat. I have yet to find the serial number on one of these engines. It is supposed to be on the right rear of the block (behind the blower??).
BKahler
Post by BKahler » Sun Mar 08, 2009 6:58 am
I have a late model 440ICD and mine had the short breather tube. Also I did manage to find the serial number but at the moment can't remember where I found it. Seems like it was in one of the top corners.
I vaguely recall mine having the inspection hole but I can't seem to locate a picture that shows it and the motor is about 600 miles away from me at the moment.
Here is a picture showing the breather tube:
Brad
switchhappy
Post by switchhappy » Sun Mar 08, 2009 9:10 am
so its right under the govners, and right between the oil lines and sender unit line.... ill look one more time but i cant find it..
switchhappy
Post by switchhappy » Sun Mar 08, 2009 11:08 am
found it.. thanks for the info mine was pluged off, the last owner put a pipe plug in it... but sad to say its blowing oil out that hole.. so my blower seals are shot.. how do i take this blower off so i can get it fixed.. or havesome fix it
Users browsing this forum: No registered users and 48 guests
