Final drive?
Final drive?
OK I have another dumb question? I pulled the covers of the adjustments for the steering controls,It wont steer to the left. When i pull the steeing lever it appears the pressureplate is moving up and down,when the band tightens on it.the other side does not do this,'
So i guess i have 2 questions. #1 how do you adjust the steering and brake band. and #2 what do you think is the problem with the pressureplate floating around?
Thanks guys
Thanks guys
- Mark Birdeau
puttputt, I'll try to answer your second question first. It could be a couple of things. If just the pressure plate is moving it isn't attached tightly to the clutch assembly. If the whole assembly is moving then the bearings are most likely bad. There also are other possibilities like a busted shaft.
As to the first question it is a several step process, the best thing is to have a manual to guide you through it. I don't have my book handy and I don't remember the exact procedure and correct dimensions. Basically, first you need the steering lever held in position to adjust the free play(I use a flat blade screwdriver between the lever and the stop) you then adjust the throw out bearing against the fingers, then the brake band and the brake actuator are adjusted.(I don't remember which gets adjusted first) Hope this helps some and good luck. Mark:
Ok I got her apart and everything looks good,a little rust on the plates.but it has 9 fiber disc,im thinking theres one to many so i leave on out and stick it back together and everything lines up fine and works, or will at least release when i pull the steer lever...BUT. theres 8 fiber discs with teeth to slide over the gear and one with nothing in the centre....
Does the one with nothing in the centre go in first or is it just an oddball someone thru in for a shim???? Thanks guys
The only difference is whether you start with a steel or a fiber. Look at the bottom of the drum around the center hub that goes over the pinion shaft. You will have to have the drum clean, the letters are small and shallow, but I think it says what disc to start with. If it is fiber, then it is a 15 plate clutch, if it is steel, then it is a 16 plate clutch.
If you run two similar discs together, you forfeit 2 friction surfaces because there is no intermediate disc for them to drive or be driven by.
Users browsing this forum: original possum and 27 guests
