repairing track adjusters 440ic
Threw a track yesterday and in putting it back on, noticed that the right side track adjuster was blowing grease from around the rod.
How much of a job is it to remove one of these? Mine has a "Shroud" around the rear portion...does this come off?
Move the track so the pin is to the lower rear of the drive sprocket. Remove the pin. Lay the track off forward. Unbolt the adjuster from the front idler wheel. Slide the idler wheel forward on the rails. Lift out the adjuster.
Open the adjuster setscrew to release the grease pressure. Push the adjuster piston in a little. Remove the internal snap ring. Pull out the piston. Replace the seals.
It may be less work than you did replacing the thrown track yesterday (and it may be the reason the track came off).
- thomastractorsvc
- Contact:
Another way without pulling the track is block the front idler. Crack loose the 4 bolts on the track adjuster remove the grease bolt and allow idler to pull back a little then block the idler slide. I would use heavy C-clamp or vise grip on front and block of hard wood on rear so that it cannot move finish removing bolts take out and replace seals they are only between $11-$20 for kit depending on where you get them or drop off at a shop. I have had to lift the front of the track up a little with the blade before, it helps to take the pressure off when you compress the adjuster. Then I set it back down. I am sure Lavoy has them to.
Rob
- john lewis
Users browsing this forum: original possum and 30 guests
