I have a four-roller 420 that I am having trouble getting the tracks to line up (pull tight) enough to get the pin through them. Does anyone have a tip or suggestion of how to make this work a little easier.
Thanks in advance
GC
John Deere 420 Tracks
420 tracks
GC,
I tried to post earlier and it got lost in cyberspace.One way
for getting track back together is to work the split
on the sprocket then the sprocket teeth will hold each end
close enough to get the pin in.Get the split at about three
oclock and you will be good to go.JimAnderson
- steamfitter99
- Jimmy in NC
I know Coleman's Military Surplus sells them for ~$25. They are in PA and I forget the website but I'm sure it can be found with a google search.
Streamfitter- how well does that track jack work? I know i asked about one a few months ago and am about to be putting a track back together. Didn't know if it would be worth it. I know some people have said just use the sprocet method as a track jack you have to tension the whole thing / support it in the center as you do it.
Jimmy in NC
Jimmy in NC
- steamfitter99
Users browsing this forum: Google [Bot] and 31 guests
