need injectors for a 1010
have a 61 model 1010 and need a set of injectors either good,new or rebuildable.any help here would be appreciated
Re: need injectors for a 1010
It depends on what injectors are in it now. The very early 1010s had injector nozzles that were obsolete by the middle 1970s. For them, the fix was - to clean up and lap the original nozzles - or - change the holders over to the newer versions that 1010s used after serial # 29,000.woody wrote:have a 61 model 1010 and need a set of injectors either good,new or rebuildable.any help here would be appreciated
If you have the later nozzles, you can buy new ones for $20 each (if things haven't changed recently).
Your best bet is to pull the complete injectors out, then pull the nozzle tips off - and get the numbers off of them.
- Tiny Crawler
Users browsing this forum: No registered users and 335 guests
