How thick does the ice need to be?
I have a JD350 crawler/loader. Does anyone know how thick lake ice needs to be to drive it across?
Thanks, Bruski
Thanks, Bruski
6" of good blue ice 3600 lb--- 7" --------- 4900 lbs
8" --------- 6400 lbs---9" --------- 8100 lbs
10" ------- 10000 lbs---11" ------- 12100 lbs
12" ------- 14401 lbs --13"---------16901 lbs
14'' ------- 19601 lbs
15" ------- 22501 lbs
16" ------- 25601 lbs
17" ------- 28901 lbs
20" ------- 40002 lbs---24"--------57604--lbs
This info comes from northen Manitoba Highways winter road builders.
They also have 1"---100-lbs-----2"---400-lbs
I have a page copied but don't know how to send it. Hope this covers
what u need.
what u need.
One thing is to watch your speed when you approach the other side. There is a pocket of air under the ice approxamately 2 to 3 vehicle lengths ahead of a heavy machine(semi truck loaded) as the machine itself will be about 2 to 3 inches below the water level. You have to leave time for the air pocket to dissipate as you come up to a solid shore. I'm not sure of the max approach speed, but 8 to 10 mph might even be on the fast side. Slush along cracks in the ice if the snow is deep can get tricky too. The snow would have to be a 10" average to be real problems.
Lbs/ sq in of track surface compared to tire surface is a big advantage for the tracked machine too. My father and uncle diamond drilled for the mining companies back before they knew about colored pictures. One story I heard was they would tear down a model 40, fly it in in pieces put it back together use as long as the job lasted and abandon it when they flew out. Don't know the whole truth there. It's kinda like the lost gold mines in california
another thing I forgot was that Manitoba Highways would have to post ice levels and weights that the vehicle insurance would cover so a safety margin would already be there.
Been on ice alot of years and it's real hard to stop the stories. Here's to a happy new year and a model 40 that's working on it's third generation of fisherman.
One more ice story
Couldn't help to read your thoughts about driving a dozer over ice, about 8 or 10 years ago a guy over in New Hampshire not far from where I live was returning a dozer he borrowed, he decided to cut a cross a lake at night, he left behind a wife and kids and I don't know if they ever did get the dozer from the bottom of the lake.
I went to SD this week for work, and picked up a brochure about driving on ice from their division of game, fish, and parks. This brochure is titled "Caution! Weak Ice".
Anyhow, I thought it was interesting as this brochure indicated that there had been studies conducted by the U.S. Army that show there is a "critical velocity" depending on the depth of water beneath the ice at which cracks will be initiated propogated by wave action beneath the ice. You're fine if slower or faster than the critical veolcity, but at the critical velocity the chances of cracking the ice are greater.
This is what they showed on the table in the brochure:
Critical Velocity of Moving Loads on Ice
Water Depth (feet) 4 6 8 10 15 20 30
Critical velocity (mph) 9 11 12 14 17 19 22
Thought it might help someone who drives a truck on ice; I doubt anyone is going to get their crawler moving that fast.
Users browsing this forum: No registered users and 32 guests
