1959 440ICD Chains and pads
frsanford
Post by frsanford » Sun Dec 30, 2007 3:29 am
Once again I thank you Lavoy for your comprehensive response to my situation on the issue of 350 chains fitting my 440. Your response leads me to ask, will his 350 sprockets bolt on to the 440? If not where do I go next to inquire about re-rimming my sprockets with the 350 rim?
I will be calling you soon with parts request for my steering clutches and brake parts...I had to drop the final drive assembly due to a broken brake band adjusting stud. While I have it apart I might as well go through it.
Thanks again for the time and effort you put in to preserving old iron!
Post by Lavoy » Sun Dec 30, 2007 1:06 pm
350 sprockets will not fit, completely different. Availability right now on 350 rims is limited, don't know why. Worst case scenario, you just cut the rim off of a 350 sprocket and use it.
Users browsing this forum: original possum and 58 guests
