Valve clearance for 1010 diesel
Rick1010
Post by Rick1010 » Fri Sep 16, 2005 11:57 am
Just picked up a '64 1010 4-cyl diesel. Doing the servicing now...anyone know what the clearance should be for the valves?
Best Regards
Rick
bighamlin
Post by bighamlin » Sun Sep 18, 2005 6:10 pm
according to SM2034;
Intake .012
Exhaust .018
jdman
Post by jdman » Tue Sep 20, 2005 9:58 am
Yup Those # Are Right.... Does Your 1010 Run And Start Good??????? I Have One With New Sleeve Deck, New Pistons And Rings, New Valves And Head Job, Rebuilt Pump And Injectors... Over 3000.00 In The Engine And It Is A Bear To Start And Sound Bad..... I'am Still Looking For Ideas...... Good Luck......
Jeff
Post by Lavoy » Tue Sep 20, 2005 12:32 pm
Jeff,
Are your glow plugs all working, and are you using them every time? How long are you preheating before starting?
A 1010 diesel on an 80 degree day that has not been run that day will need to be preheated at least 30 seconds before it will start. If it has the primer attachment, it will say to give it two strokes of primer while preheating. Don't make the assumption that just because it is new and tight it will start without preheating.
We were using my brother's 1010 diesel this weekend. It was in the mid 80's here, and I preheated it for almost a minute and gave it two strokes on the primer, and it fired right off. This is not a new engine by any means, and I have started it without ether below 20 degrees by preheating and priming.
jdman
Post by jdman » Wed Sep 21, 2005 9:38 am
Thanks Lavoy... My Primer is Not Working, And I Am Going To Order A Set Of New Glow Plugs... And Go From There......
Jeff
Post by Lavoy » Wed Sep 21, 2005 9:54 am
O-rings may get the primer working.
I have glow plugs if you have the late style.
JD40c
Post by JD40c » Fri Sep 23, 2005 8:30 am
If the injection pump timing is off, could that cause it not to run smoothly? Or is the timing adjustable?
Post by Lavoy » Fri Sep 23, 2005 8:52 am
Yes, they are adjustable, but not sure it timing affect a diesel like a gas.
I think what he was referring to is when first started. When first starting a 1010 diesel without primer or glow plugs, it will hit on about as many cylinders as a 420 for a while.
Rick1010
Post by Rick1010 » Tue Sep 27, 2005 12:28 pm
Many thanks for the valve gap info.
Regarding the starting, the guy I bought the machine from told me to always preheat the glow plugs for 30 seconds no matter the outside temperature. Seemed to work good for him.
Rick
Post by Lavoy » Tue Sep 27, 2005 3:18 pm
30 seconds is for warm weather. Once it gets a little cooler, it is a minute, and below freezing it is 2 minutes and 3 or 4 strokes of primer.
Users browsing this forum: Majestic-12 [Bot] and 10 guests
