I split the track today and the master pin had a tack of weld on the inside, should I re-tack it?
How would the fan belt come out, do you have to take off the hydraulic pump?
Why does the hydraulic pump disengage with a lever?
Thanks Chad
More 1010 Questions
If the pin fits tight, and the snap ring groove is good, should not need to tack it. If not, then it won't hurt anything.
Pump disconnect is for starting in cold weather. Not sure if you can snake the belt through the coupler or not. Take the grille off, and you should have better access through the front.
Users browsing this forum: Google [Bot] and 11 guests
